Aircraft Hardware AN MS and NAS Part Quick Guide
ISO Metric Hardware | ANSI Hardware Guide
Hardware Supplier & Manufacturer
Military, Aerospace Hardware Selection Guide for AN, MS and NAS hardware. Each page includes pictoral references, part numebr and a short description.
PART NUMBER
DESCRIPTION
AN 42- AN 365
Eye Bolt, Hinge, Nut, Balls, Pulley, Wing Nut
AN 366 - AN 656
Nut Plate, Screw, Taper Pin, Clevis, Rod Ends
AN 658 - AN 117080
Terminal, Lug. Fittings, Bolt, Washer, Screw
AN 121501 - MS9168
Nut, Lock Pin, O-Ring, Snap Ring, Stud
MS 9169 - MS 16108
Bolt, Washer, Clamp, Nut, Bracket, Stud
MS 16187 - MS 16634
Stud, Lock Ring, Dowel Pin, Bolt, Nut
MS 16637 - MS 20253
Shoulder Screw, Terminal, Nut, Machine Key
MS 20257 - MS 21261
Hinge, Rivet, Nut, Turn Buckle, Lock Pin
MS 21262 - MS 24371
Socket Screw, Nut, Fittings, Misc..
MS 24388 - MS 24405
Fittings, Tapping Screw, Blind Rivet, Misc...
MS 27039 - MS 28778
Screw Pan Head, Hinge, Packing, Misc..
MS 28782 - MS 35691
Screw, Terminals, Wood Screws, Washers
MS 35743 - MS 172370
Rivets, Nut, Threaded Insert, Bolt, Screws
NAS 1 - NAS 330
Rivet, Rings, Bolts, Rod Assy., Bus Bar
NAS 333 - NAS 491
Screws, Bearing, plug, Washer, Clamp, Misc.
NAS 492 - 574
Misc.
NAS 577 - NAS 1044
Locking Nut, Rings, Shackle, Screws, Misc...
NAS 1045 - 1221
Cable Guide, Nut, Toggle Switch, misc..
NAS 1222 - 1401
Threaded Insert, Nut, Screws, Hose Clamp
NAS 1402 - 1406
Screw, Threaded Rod, U Bolt, Misc.
