Engineering Reliability Statistical Models
Engineering Statistics and Probability Knowledge
There are many standard statistical distributions which may be used to model the various engineering and reliability parameters. It has been found that a relatively small number of statistical distributions satisfies most needs in engineering and reliability work. The particular distribution used depends upon the nature of the data, in each case.
The following are some of the distributions most commonly used in engineering and reliability analysis, criteria for their use, and examples of application. The tables below, Table A and B are summaries of the shape of common failure density, reliability, and hazard rate functions for the distributions described.
Type of Distribution Probability Density Function, f(t)
Exponential Exponential Probability Density Function, f(t)
Gamma Gamma Probability Density Function, f(t)
Lognormal Lognormal Probability Density Function, f(t)
Normal Normal Probability Density Function, f(t)
Weibull Weibull Probability Density Function, f(t)
Table A
Reliability Function R(t) = 1 - f(t)
Exponential Exponential Reliability Function R(t) = 1 - f(t)
Gamma Gamma Reliability Function R(t) = 1 - f(t)
Lognormal Lognormal Reliability Function R(t) = 1 - f(t)
Normal Normal Reliability Function R(t) = 1 - f(t)
Weibull Weibull Reliability Function R(t) = 1 - f(t)
Hazard Function
 Hazard Function
Exponential Exponential Hazard Function
Gamma Gamma Hazard Function
Lognormal Lognormal Hazard Function
Normal Normal Hazard Function
Weibull Weibull Hazard Function
Cumulative Distributive Function Formula
Parameters
Binomial Binomial Parameters
Sample data used to plot charts shown
Poisson Poisson Parameters
Probability of Density Function f(x)
Binomial Binomial Probability of Density Function f(x)
Binomial formula
Poisson Poisson Function Probability of Density Function f(x)
Poisson
R(x) = 1-F(t)
Binomial Binomial Reliability Function
Poisson Poisson Reliability Function
Poisson Function
