Polar Mass Moment of Inertia, Common Shape Equations and Calculator
Engineering Metals and Materials Table of Contents
Engineering Analysis Menu
Polar Mass Moment of Inertia About Axis A-A, Axis B-B and Axis C-C.
Related: Polar Area Moment of Inertia and Section Modulus.
Mass Moments of Inertia, JM. formulas for mass moment of inertia of various solids are given below.
Example, Polar Mass Moment of Inertia of a Hollow Circular Section:
A strip of width dr on a hollow circular section, whose inner radius is r and outer radius is R.
The mass of the strip = 2πrdrρ, where ρ is the density of material. In order to get the mass of an individual section, integrate the mass of the strip from r to R.
The 2nd moment of the strip about the AA axis = 2πrdrρr2. To find the polar moment of inertia about the AA axis, integrate the 2nd moment from r to R.
Note: In some many engineering examples the symbol I denotes the polar moment of inertia of masses; JM is used here to avoid confusion with moments of inertia of plane areas.
JM = Polar Mass Moment of Inertia (in-lbs-sec2, Kg-m-sec2)
h, b, l, L = Distance (in, m)
M = Mass = ρL = (lb - sec2 / in, N - Sec2 / m )
ρ = Density
All calculators require a java enabled browser and a Premium Membership Account.
Section
Mass Polar Moment of Inertia
Axis A-A
JM
Axis B-B
JM
Prism
Square Section
Mass Polar Moment of Inertia Axis A-A
Mass Polar Moment of Inertia Axis B-B
Cylinder
Open
Polar Mass Moment of Inertia Cylinder Calculator
Hollow Cylinder
Open
Polar Mass Moment of Inertia Hollow Cylinder Calculator
Pyramid, Rectangular Base
Open
Polar Mass Moment of Inertia Pyramid, Rectangular Base Calculator
Through the center of gravity
Sphere
Open
Polar Mass Moment of Inertia Sphere Calculator
Spherical Sector
Mass Polar Moment of Inertia  Cylinder
Open
Polar Mass Moment of Inertia Spherical Sector Calculator
Spherical Segment
Open
Polar Mass Moment of Inertia Spherical Segment Calculator
Torus
Open
Polar Mass Moment of Inertia Torus Calculator
Paraboloid
Open
Polar Mass Moment of Inertia Parabolid Calculator
Cone
Open
Polar Mass Moment of Inertia Cone Calculator
Frustrum of Cone
Open
Polar Mass Moment of Inertia Frustrum of Cone Calculator
Section
Axis A-A
JM
Axis B-B
JM
Axis C-C
JM
Ellipsoid
Open
Polar Mass Moment of Inertia Ellipsoid Calculator
Mass Polar Moment of Inertia Axis C-C
Contribute Article
