Two Pulley Connecting Belt Design and Calculations
Mechanics & Machine Calculations
The following equations will determine: Speed Ration, Arc of contact, Tension ration for belt about to slip, Power Capacity, Pulley Torque, Initial Tension
Symbols Used in Calculations
Pulley Speed Ratio
Two Pulleys Belt
Tension ratio for belt about to slip:
Tension Ratio Belt
Power capacity:
Belt Power Capacity
Pulley Torque
Pulley Torque Equation
Pulley Initial Tension
Effect of centrifugal force: the belt tensions are reduced by mv2 so that:
Pulley Centifugal FOrce
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
