Multiple Pulley's Lifting Mechanical Advantage
The illustration below shows a combination of a double and triple block pulley system. The pulleys each turn freely on a pin as axis, and are drawn with different diameters, to show the parts of the rope more clearly. There are 5 parts of rope.
Note: For rope (n1, n2, etc.), the velocity which the weight W will be raised equals of the velocity of the force applied at F.
Force to Raise Load:
F = eW/n
Pulley Mechanism
Weight Lifted by known force:
W = nF/e
Velocity ratio VR = n
where: n = number of ropes between the sets of pulleys (= 5 in figure).
W = Unknown weight
F = Applied force
n = number of ropes or cables
e = efficiency
