Multiple Pulley's Lifting Mechanical Advantage
The following are the equations and calculator to determine the lifting forcing and velocity ratio of a differential pulley.
Force to Raise Load:
F = eW/(VR)
Velocity ratio VR = 2/[1-r/R]
W = Load (lbs, N)
F = Applied force (lbs, N)
r = Radius (in, mm)
R = Radius (in, mm)
e =efficiency (%)
