Composite Position Tolerance GD&T Calculator for Internal FOS
Mechanical Engineering Tolerances Resources
GD&T Composite Position Tolerance Calculator for Dimensional Inspection:
Internal Feature of Size - hole, slot, cutout, etc..
Composite Feature Control Frame
Assumptions:
  • Applies to an Internal Feature of Size (Hole, slot, etc..)
  • PLTZF tolerance applied at MMC
  • FRTZF tolerance applied at MMC
  • All dimensional unit applied with uniform units - all inches, mm, m, etc.
  • Datum applied at RFS
  • FRTZF datum is perpendicular to features
  • X and Y measurements taken with datum's established
  • Up to fifteen (15) features can be calculated
  • Feature #1 is used as the origin for the FRTZF position tolerance calculations
Preview:
For information on the equations used in this calculator, see:
Geometric Boundaries, II - The Interpretation and Application of GD&T per. ASME Y14.5-2009
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
