Rectangular Plate Uniform Load Simply Supported Equations and Calculator
Rectangular plate, uniform load, simply supported (Empirical) equations and calculator
Since comers tend to rise off the supports, vertical movement must be prevented without restricting rotation.
Symbols used:
a = minor length of rectangular plate, (m, in)
b = major length of rectangular plate, (m, in)
p = uniform pressure loading, (Pa, lbs/in2)
v = Poisson’s ratio
E = Young’s modulus, (N/m2, lbs/in2)
t = plate thickness, (m, in)
s m = maximum stress, (N/m2, lbs/in2)
ym = maximum deflection, (m, in)
Circular plate, uniform load, edges clamped equation and calculator
Stress At Center
Stress At Center
Deflection at center
Deflection at center, v = 0.3
D = flexural rigidity= Et3/(12 ( 1 -v2)
