Rankine Gordon Equation
Strength of Materials
Predictions of buckling loads by the Euler formula is only reasonable for very long and slender struts that have very small geometrical imperfections. In practice, however, most column struts suffer plastic knockdown and the experimentally obtained buckling loads are much less than the Euler predictions. For struts in this category, a suitable formula is the Rankine Gordon equation which is a semi-empirical formula, and takes into account the crushing strength of the material, its Young's modulus and its slenderness ratio.
A comparison of the Rankine-Gordon and Euler equation, for geometrically perfect struts, is given below:
Comparison of Euler and Rankine-Gordon equation
Columns
least radius of gyration
σ = failure stress
σc = elastic limit in compression
a = constant
A = cross-sectional area
k = least radius of gyration
L = Length
P = Buckling Load
I = Area moment of Inertia
Material
σc
Mpa
a
Pinned Ends
Fixed Ends
Mild Steel
320
1/7500
1/30000
Wrough Steel
250
1/9000
1/36000
Cast Iron
550
1/1600
1/6400
Wood
35
1/3000
1/12000
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
