Circular Plate Edges Clamped Uniform Load Equation and Calculator
Equation is given for the maximum stress and deflection for circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported. In practice, the edge conditions are usually uncertain and some compromise must be made. The equations are only valid if the deflection is small compared to the plate thickness.
Symbols used:
r = radius of circular plate, (m, in)
p = uniform pressure loading, (N, lbs)
v = Poisson’s ratio (often assumed to be 0.3)
E = Young’s modulus, (N/m2, lbs/in2)
t = plate thickness, (m, in)
s m = maximum stress, (N/m2, lbs/in2)
ym = maximum deflection, (m, in)
Circular plate, uniform load, edges clamped equation and calculator.
Circular Plate Stress Deflection
Stress At Edge
Stress At Center
Deflection at center
Deflection at center, v = 0.3
D = flexural rigidity= (Et3/12)( 1 -v2)
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
