Bolt or Pin In Single Shear Equation and Calculator
Strength / Mechanics of Materials
Beam Deflection & Structural Analysis
Bolt or Pin In Single Shear Equation and Calculator. Keep units consistant when performing calculations.
Shear Stress Equation Single Shear
Shear Stress Average = Applied Force / Area
or
Shear Stress ave.= F/( π r 2)
or
Shear Stress ave.= 4F/( π d 2)
Shear Stress ave = ( N/mm2, lbs/in2)
F = Applied Force (N, Lbs)
π = pi or (3.14157)
r = Radius (mm, in.)
d = Diameter (mm, in.)
Bearing Area Stress Equation for Plate and Bolt or Pin
Bt= F / (t d)
Bt = Bearing Area Stress Area ( N/mm2, lbs/in2)
F = Applied Force (N, lbs)
t = Thickness (mm, in)
d = Diameter (mm, in)
Factor of Safety
Factor of Safety = F.S = ultimate stress / allowable stress
Therefore:
allowable stress = ultimate stress / F.S.
