Modulus of Elasticity, Strength Properties of Non-Metals Ultimate Strength, Yield Strength, Modulus of Elasticity
Engineering Metals and Materials
Table of Modulus of Elasticity, Strength Properties of Non-Metals Ultimate Strength, Yield Strength, Modulus of Elasticity
 Material
Ultimate Strength
x 1000/in2
Yield Strength
(0.2 % offset)
x 1000/in2
 x106/in2
in Tension in Shear in Tension
E
in Shear
G
Aluminum Alloys, Cast
   Sand cast
10 to 35
 14 to 26
8 to 25 10.3
   Heat treated
 20 to 48
 20 to 34
16 to 40 10.3
Permanent Mold Cast
23 to 35
 16 to 27
9 to 24 10.3
   Heat Treated
23 to 48
 15 to 36
8.5 to 43 10.3
Die-Cast
30 to 46
 19 to 29
16 to 27 10.3
Aluminum Alloys Wrought
   Annealed
10 to 42
7 to 26
4 to 22 10.0 to 10.6
   Cold Worked
12 to 63
 8 to 34
11 to 59 10.0 to 10.3
   Heat Treated
22 to 83
13 to 48
13 to 73 10.0 11.4
Aluminum Bronze, Cast
62 to 90
25 to 37 15 to 18
   Heat Treated
80 to 110
32 to 65 15 to 18
Aluminum Bronze, Wrought
   Annealed
55 to 80
20 to 40 16 to 19
   Cold Worked
71 to 110
62 to 66 16 to 19
   Heat Treated
101 to 151
48 to 94 16 to 19
Brasses, Leaded, Cast
32 to 40
25 to 31
12 to 15 12 to 14
   Flat Products, Wrought
46 to 85
31 to 45
14 to 62 14 to 17
5.3 to 6.4
   Wire, Wrought
50 to 88
34 to 46
...... 15
5.6
Brasses, Non-Leaded
   Flat Products, Wrought 34 to 99 28 to 48 10 to 65 15 to 17 5.6 to 6.4
   Wire, Wrought 40 to 130 29 to 69 ...... 15 to 17 5.6 to 6.4
Copper, Wrought
   Flat Products
32 to 57
22 to 29
10 to 53 17
6.4
   Wire
35 to 66
24 to 33
...... 17
6.4
Inconel, Cast
70 to 95
30 to 45 23
80 to 170
30 to 160 31
11
   Wire, Wrought
80 to 185
25 to 175 31
11
Lead
2.2 to 4.9
...... 0.8 to 2.0
Magnesium, Cast, Sand and Permanent Mold
22 to 40
17 to 22
12 to 23 6.5
2.4
   Die Cast
33
20 22 6.5
2.4
Magnesium, Wrought
   Sheet and Plate 35 to 42 21 to 23 20 to 32 6.5 2.4
   Bars, Rods and Shapes 37 to 55 19 to 27 26 to 44 6.5 2.4
Monel, Cast 65 to 90 63 to 162 32 to 40 19 ......
   Flat, Products, Wrought 70 to 140
35 to 130 26 9.5
   Wire, Wrought 70 to 170
25 to 160 26 9.5
Nickel, Cast 45 to 60
20 to 30 21.5 ......
   Flat Products, Wrought 55 to 130
15 to 115 30 11
   Wire, Wrought 50 to 165
10 to 155 30 11
Nickel Silver Cast 40 to 50
24 to 25 ...... ......
   Flat Products, Wrought 49 to 115 41 to 59 18 to 90 17.5 to 18 6.6 to 6.8
   Wire, Wrought 50 to 145
25 to 90 17.5 to 18 6.6 to 6.8
Phosphor Bronze Wrought
   Flat Products 40 to 128
14 to 80 15 to 17 5.6 to 6.4
   Wire 50 to 147
20 to 80 16 to 17 6 to 6.4
Silicon Bronze, Wrought
   Flat Products 56 to 110 42 to 63 21 to 62 15 5.6
   Wire 50 to 145 36 to 70 25 to 70 15 to 17 5.6 to 6.4
Tin Bronze, Leaded, Cast 21 to 38 23 to 43 15 to 18 10 to 14.5 ......
Titanium 50 to 135
40 to 120 15.0 to 16.5 ......
Zinc, Commercial Rolled 19.5 to 31
Zirconium 22 to 83
...... 9 to 14.5 4.8
