Heat Loss Isothermal Cylinder buried in a semi-infinite medium
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Steady State Rate of Heat Loss of Isothermal Cylinder
Isothermal cylinder of length L buried in a semi-infinite medium (L >>D and z >1.5D)
Isothermal Cylinder
Preview: Isothermal cylinder of length L buried in a semi-infinite medium Calculator
Thermal Conduction Equation
T1 = Temperature (°C)
T2 = Temperature (°C)
D = Diameter (m)
L = Length (m)
z = Distance (m)
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
