Conductive Heat Transfer Eccentric Cylinder Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of Eccentric circular isothermal cylinder of length L in a cylinder of the same length (L > D2).
Preview: Conductive Heat Transfer Eccentric Cylinder Calculator
Thermal Conduction Equation
Steady State Constant
Cosh
T1 = Temperature (°C)
T2 = Temperature (°C)
D1 = Diameter (m)
D2 = Diameter (m)
z = Distance (m)
L = Length (m)
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
