Plastic PVC, CPVC Pipe Applications
Fluid Flow Table of Contents
Chart gives material characteristics for plastic PVC, CPVC, other pipes commonly found within industrial and residential use within North America.
Material
General Properties
Recommended Use
ABS (Acrylonitrilebutadiene styrene)
Rigid; excellent impact strength at low temperatures; maintains rigidity at higher temperatures. Water, Drain, Waste, Vent, Sewage.
PE (Polyethylene)
Flexible; excellent impact strength; good performance at low temperatures. Water, Gas, Chemical, Irrigation.
PVC (Polyvinylchloride)
Rigid; fire self-extinguishing; high impact and tensile strength. Water, Gas, Sewage, Industrial process, Irrigation.
CPVC (Chlorinated polyvinyl chloride)
Rigid; fire self-extinguishing; high impact and tensile strength. Hot and cold water, Chemical.
PB
(Polybutylene)
Flexible; good performance at high temperatures. Water, Gas, Irrigation.
PP (Polypropylene)
Rigid; very light; high chemical resistance, particularly to sulfur-bearing compounds. Selected Chemical waste and processing.
SR (Styrene rubber plastic)
Rigid; moderate chemical resistance; fair impact strength. Drainage, Septic fields.
Material
Operating Temperature
Typical assembly or joining methods
Pressure Applied Pressure NOT Applied
100°F 180°F Solvent cement, Threading, Transition fitting.
PE (Polyethylene)
100°F 180°F Heat fusion, Insert and Transition fitting.
100°F 180°F Solvent cement, Elastomeric seal, Mechanical coupling, Transition fitting.
180°F at 100 psig Solvent cement, Threading, Mechanical coupling, Transition fitting.
PB
(Polybutylene)
180°F 200°F Insert fitting, Heat fusion, Transition fitting.
PP (Polypropylene)
100°F 180°F Mechanical coupling, Heat fusion, Threading.
150°F Solvent cement, Transition fitting, Elastomeric seal.
Adapted from materials provided by the Plastics Pipe institute
Manufacturers’ Recommendationsa, b for Plastic Materials
Application
PVC
CPVC
HDPE
PEX
PP
ABS
PVDF
RTRP
Cold-water service
R
R
R
R
R
R
R
R
Hot (140°F) water
N
R
R
R
R
R
R
R
Potable-water service
R
R
R
R
R
R
R
R
Drain, waste, and vent (DWV)
R
R
R
R
Demineralized water
R
R
R
R
R
Deionized water
R
R
R
R
R
R
Salt water
R
R
R
R
R
R
R
Heating (200°F) hot water
N
N
N
N
N
N
R
Natural gas
N
N
R
R
N
N
Compressed air
N
N
R
R
N
R
Sunlight and weather resistance
N
N
R
R
R
R
R
Underground service
R
R
R
R
R
R
R
Food handling
R
R
R
R
R
R
a Before selecting material, check availability of suitable range of sizes and fittings and of satisfactory joining method. Also have manufacturer verify the best material for purpose intended.
b Consult local building codes for compliance of materials listed.
Source: ASHRAE Handbook Fundamentals
