Loss of Air Pressure Due To Pipe Friction Table 2
Fluid Flow Table of Contents
Loss of Air Pressure Due To Pipe Friction Table Chart 2
To determine the pressure drop in psi, the factor listed in the table for a given capacity and pipe diameter should be divided by the ratio of compression (from free air) at entrance of pipe, multiplied by the actual length of the pipe in feet, and divided by 1,000.
