U-Tube Manometer Measuring Pressure
Density (kg/m3 , lb/in3) =
Height Difference (m, in) =
Gravity (9.81 m/s2 , 32.174 in/s2) =
Pressure (N/m2, lb/in2) =
U-Tube Manometer Differential Pressure
Density p1 (kg/m3 , lb/in3) =
Density p2 (kg/m3 , lb/in3) =
Pressure Differential (N/m2, lb/in2) =
Single-Leg Manometer - Gauge Pressure
Density pm (kg/m3 , lb/in3) =
Inclined Single-Leg Manometer Measured Pressure
Length (m, in) =
angle (degrees) =
Inverted U-Tube Manometer Equation
Density pf (kg/m3 , lb/in3) =
