Estimated Pressure Drop for Thermoplastic Lined Fittings and Valves
Fluid Flow Table of Contents
The following table chart defines the Estimated Pressure Drop for Thermoplastic Lined Fittings and Valves.
All values are in psi
Size
mm (in)
Standard
90 deg. elbow
Standard Tee
Plug Valve
Diaphram Valve
Vertical Check Valve
Horizontal Check Valve
Through run
Through run branch
25 (1)
0.55 (1.8)
0.37 (1.2)
1.4 (4.5)
0.61 (2.0)
2.1 (7)
1.8 (6.0)
4.9 (16)
40 (1½)
1.1 (3.5)
0.70 (2.3)
2.3 (7.5)
1.3 (4.2)
3.0 (10)
1.8 (6.0)
7.0 (23)
50 (2)
1.4 (4.5)
0.91(3.0)
3.0 (10)
1.7 (5.5)
4.9 (16)
3.0 (10)
14 (45)
65 (2½)
1.7 (5.5)
1.2 (4.0)
3.7 (12)
N.A.
6.7 (22)
3.4 (11)
15 (50)
80 (3)
2.1 (7.0)
1.2 (4.1)
4.6 (15)
N.A.
10 (33)
3.7 (12)
18 (58)
100 (4)
3.0 (10)
1.8 (6.0)
6.1 (20)
N.A.
21 (68)
6.1 (20)
20 (65)
150 (6)
4.6 (15)
3.0 (10)
9.8 (32)
N.A.
26 (85)
9.4 (31)
46 (150)
200 (8)
5.8 (19)
4.3 (14)
13 (42)
N.A.
46 (150)
23 (77)
61 (200)
250 (10)
7.6 (25)
5.8 (19)
16 (53)
N.A.
N.A.
N.A.
N.A.
300 (12)
9.1 (30)
7.0 (23)
20 (64)
N.A.
N.A.
N.A.
N.A.
Notes:
Data is for water expressed as equal length of straight pipe in m (ft)
N.A. = Part is not available from source.
“Plastic Lined Piping Products Engineering Manual”
