Burst Pressure of Pipe or Tubing Barlow's Formula
Fluid Flow Table of Contents
Burst Pressure of Pipe or Tubing Equation
The following equation is Barlow's formula and can be used to estimate burst pressure of pipes.
    P = (2t x S) / D
P = is burst pressure in PSI
t = is wall thickness, in inches
S = is allowable or tensile strength of material in PSI
D = is outside diameter, inches
It is recommended that the estimated bursting pressure be smaller by some factor of safety.
The design of a complex pressure containment system involves much more than the application of Barlow's formula. For almost all pressure vessels , the ASME code stipulates the requirements for design and testing.
Related Resources:
