API Tubing Engineering Table Chart
Fluid Engineering Data | Pumps Engineering Data
API Tubing Engineering Data Chart: When placing orders for tubing to be manufactured in accordance with API Spec. 5CT, the purchaser should consult APISpec. 5CT Sec. 4. At a minimum, the following requirements should be specified on the purchase order:
  • The specification (API/ISO)
  • Quantity
  • Size designation [outside diameter (OD), normally in inches]
  • Weight designation
  • Grade and type
  • End finish (type of connection)
  • Range length
  • Seamless or electric weld
  • Delivery date
  • Shipping instructions
API tubing specifications contain several provisions that are optional for the purchaser and other stipulations that are by agreement between the purchaser and the manufacturer. Some of these added provisions may be critical to a particular application; therefore, familiarity with API/ISO tubing specifications is needed.
O.D.
(inch)
NOMINAL
WEIGHT
T&C (lbs/ft)
GRADE
COLLAPSE (psi)
INTERNAL YIELD PRESSURE at
MINIMUM YIELD (psi)
JOINT STRENGTH(lbs)
BODY
YIELD
(lbs)
WALL
(inch)
I.D.
(inch)
DRIFT
DIAMETER
(inch)
NUE
T&C
EUE
T&C
PE,
NUE
T&C
BUTTR
. T&C
EUE T&C
NUE
T&C
BUTTR.
T&C
EUE
T&C
REGULAR
CPL.
SPEC.
CPL.
1.05
1.14
1.2
7680
7530
7530
6360
13300
13300
0.113
0.824
0.73
1.05
1.14
1.2
10560
10360
10360
8740
18300
18300
0.113
0.824
0.73
1.05
1.14
1.2
12480
12240
12240
10330
21600
21600
0.113
0.824
0.73
1.05
1.14
1.2
15370
15070
15070
12720
26600
26600
0.113
0.824
0.73
1.05
1.14
1.2
15370
15070
15070
12720
26600
26600
0.113
0.824
0.73
1.05
1.14
1.2
18250
17890
17890
15100
31600
31600
0.113
0.824
0.73
1.25
1.7
1.8
7270
7080
7080
10960
19800
19800
0.133
1.049
0.955
1.25
1.7
1.8
10000
9730
9730
15060
27200
27200
0.133
1.049
0.955
1.25
1.7
1.8
11820
11500
11500
17800
32100
32100
0.133
1.049
0.955
1.25
1.7
1.8
14550
14160
14160
21910
39500
39500
0.133
1.049
0.955
1.25
1.7
1.8
14550
14160
14160
21910
39500
39500
0.133
1.049
0.955
1.25
1.7
1.8
17270
16810
16810
26020
46900
46900
0.133
1.049
0.955
1.5
2.3
2.4
6180
5900
5900
15530
26700
26700
0.14
1.38
1.286
1.5
2.3
2.4
8490
8120
8120
21360
36800
36800
0.14
1.38
1.286
1.5
2.3
2.4
10040
9590
9590
25240
43500
43500
0.14
1.38
1.286
1.5
2.3
2.4
12360
11810
11810
31060
53500
53500
0.14
1.38
1.286
1.5
2.3
2.4
12360
11810
11810
31060
53500
53500
0.14
1.38
1.286
1.5
2.3
2.4
14670
14020
14020
36900
63500
63500
0.14
1.38
1.286
2
2.75
2.9
5640
5340
5340
19100
32000
32000
0.145
1.61
1.516
2
2.75
2.9
7750
7350
7350
26300
44000
44000
0.145
1.61
1.516
2
2.75
2.9
9160
8680
8680
31000
52000
52000
0.145
1.61
1.516
2
2.75
2.9
11280
10680
10680
38200
64000
64000
0.145
1.61
1.516
2
2.75
2.9
11280
10680
10680
38200
64000
64000
0.145
1.61
1.516
2
2.75
2.9
13440
12690
12690
45300
75900
75900
0.145
1.61
1.516
2.063
3.25
5590
5290
5290
35700
37400
0.156
1.751
1.657
2.063
3.25
7690
7280
7280
49100
51400
0.156
1.751
1.657
2.063
3.25
9090
8600
8600
57900
60700
0.156
1.751
1.657
2.063
3.25
11180
10590
10590
71400
74800
0.156
1.751
1.657
2.063
3.25
11180
10590
10590
71400
74800
0.156
1.751
1.657
2.063
3.25
13240
12570
12570
84700
88800
0.156
1.751
1.657
2.063
3.25
15680
14560
14560
98100
102800
0.156
1.751
1.657
2.375
4
5230
4920
30100
46300
0.167
2.041
1.947
2.375
4
7190
6770
41400
63700
0.167
2.041
1.947
2.375
4
9980
9840
60300
92700
0.167
2.041
1.947
2.375
4
9980
9840
60300
92700
0.167
2.041
1.947
2.375
4
11410
11690
71600
110000
0.167
2.041
1.947
2.375
4.6
4.7
5890
5600
5600
5600
5600
36000
52200
52200
52200
0.19
1.995
1.901
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
