API NUE Tubing Recommended Torque Table
Fluid Engineering Data
API nonupset (NUE) tubing is used much less than EUE tubing. The cost of NUE is only slightly less than EUE, and the joint strength is substantially less. The coupling joint diameter of NUE is less than EUE, which offers some advantages when clearance is small. API NUE joints are available in sizes of 1.050 to 4.500 in.
Recommended Torque Table for API NUE Tubing.
SIZE
WT/FT
GRADE
TORQUE
FT - LBS
MIN.
OPT.
MAX.
1"
1.8
J-55
200
270
340
1"
1.8
N-80
290
380
480
1 1/4"
2.4
J-55
260
350
440
1 1/4"
2.4
N-80
370
490
610
1 1/2"
4.7
J-55
310
410
500
1 1/2"
4.7
N-80
460
570
700
2 3/8"
4
J-55
460
610
760
2 3/8"
4
N-80
640
850
1060
2 3/8"
4.6
J-55
550
730
910
2 3/8"
4.6
N-80
770
1020
1280
2 3/8"
4.6
P-105
960
1280
1600
2 3/8"
5.8
N-80
1100
1460
1830
2 3/8"
5.8
P-105
1380
1840
2300
2 7/8"
6.4
J-55
790
1050
1310
2 7/8"
6.4
N-80
1100
1470
1840
2 7/8"
6.4
P-105
1390
1850
2310
2 7/8"
8.6
N-80
1660
2210
2760
2 7/8"
8.6
P-105
209
2790
3490
3 1/2"
7.7
J-55
910
1210
1510
3 1/2"
7.7
N-80
1280
1700
2130
3 1/2"
9.2
J-55
1110
1480
1850
3 1/2"
9.2
N-80
1550
2070
2590
3 1/2"
9.2
P-105
1970
2620
3280
3 1/2"
10.2
J-55
1290
1720
2150
3 1/2"
10.2
N-80
1810
2410
3010
3 1/2"
12.7
N-80
2410
3210
4010
3 1/2"
12.7
P-105
3050
4060
5080
4"
9.5
J-55
930
1240
1550
4"
9.5
N-80
1310
1740
2180
4 1/2"
12.6
J-55
1310
1740
2180
4 1/2"
12.6
N-80
1830
2440
3050
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
