Related Resources: fluid flow
API Integral-Joint tubing Recommended Torque Table
Fluids Design Engineering Data
API IJ integral-joint tubing is available in OD sizes of 1.315 to 2.063 in. API integral-joint tubing has a 10-round form with a joint strength that is less than the body minimum yield, which restricts its use. The small OD of integral-joint tubing permits its use inside larger tubing strings or in wells as unloading or vent strings. The couplings should meet all the minimum requirements outlined in API Spec. 5CT. API Spec. 5B3 and API RP 5B14 cover threading, gauging, and thread inspection.
Recommended Torque Table for IJ Tubing
SIZE
WT/FT
GRADE
TORQUE
FT-LBS
MIN.
OPT.
MAX.
1"
1.72
J-55
300
400
500
1"
1.72
N-80
410
550
690
1 1/4"
2.1
J-55
380
500
630
1 1/4"
2.33
J-55
380
500
630
1 1/4"
2.33
N-80
620
690
860
1 1/2"
2.4
J-55
440
580
730
1 1/2"
2.76
J-55
440
580
730
1 1/2"
2.76
N-80
610
810
1010
2 1/16"
3.25
J-55
560
740
920
2 1/16"
3.25
N-80
770
1030
1290
2 3/8"
4.7
J-55
1100
1300
2 3/8"
4.7
N-80
1200
1700
2 3/8"
5.3
J-55
1100
1400
2 3/8"
5.3
N-80
1400
1900
2 3/8"
5.95
J-55
1300
1600
2 3/8"
5.95
N-80
1600
2200
2 3/8"
6.2
J-55
1500
1800
2 3/8"
6.2
N-80
1800
2400
2 3/8"
7.7
J-55
1800
2100
2 3/8"
7.7
N-80
2000
2600
2 7/8"
6.5
J-55
1300
1600
2 7/8"
6.5
N-80
1800
2500
2 7/8"
7.9
J-55
1400
1700
2 7/8"
7.9
N-80
2600
3400
2 7/8"
8.7
J-55
1600
1900
2 7/8"
8.7
N-80
3000
4000
2 7/8"
8.9
J-55
1600
1900
2 7/8"
8.9
N-80
3000
4000
2 7/8"
9.5
J-55
2100
2800
2 7/8"
9.5
N-80
3500
4300
2 7/8"
10.4
J-55
2100
2800
2 7/8"
10.4
N-80
3500
4300
2 7/8"
11
J-55
2500
3200
2 7/8"
11
N-80
4000
4800
2 7/8"
11.65
J-55
2700
3400
2 7/8"
11.65
N-80
4500
5300
3 1/2"
9.3
J-55
2100
2600
3 1/2"
9.3
N-80
2400
3400
3 1/2"
10.3
J-55
2200
2700
3 1/2"
10.3
N-80
2800
3800
3 1/2"
12.8
J-55
2500
3000
3 1/2"
12.8
N-80
3200
4200
3 1/2"
12.95
J-55
2500
3000
3 1/2"
12.95
N-80
3500
4600
3 1/2"
15.5
J-55
2800
3400
3 1/2"
15.5
N-80
4200
5200
3 1/2"
15.8
J-55
2800
3400
3 1/2"
15.8
N-80
4500
5800
3 1/2"
16.7
J-55
22900
3600
3 1/2"
16.7
N-80
4500
5800
4"
9.5
J-55
2100
2500
4"
9.5
N-80
2400
2800
4"
11
J-55
2300
2800
4"
11
N-80
2500
3000
4"
11.6
J-55
2500
3100
4"
11.6
N-80
2800
3700
4"
13.4
J-55
2500
3100
4"
13.4
N-80
2800
3700
4"
22.5
J-55
2900
3500
4"
22.5
N-80
3400
4300
4 1/2"
12.75
J-55
2400
2900
4 1/2"
12.75
16.5
3000
3600
4 1/2"
13.5
J-55
2400
2900
4 1/2"
13.5
N-80
3000
3600
4 1/2"
15.5
J-55
2700
3200
4 1/2"
15.5
N-80
3300
3900
4 1/2"
16.9
J-55
2800
3300
4 1/2"
16.9
N-80
3400
4000
4 1/2"
19.2
J-55
3000
3500
4 1/2"
19.2
N-80
3700
4300
4 1/2"
21.6
J-55
3100
3600
4 1/2"
21.6
N-80
3900
4500
