GD&T Floating Fastener Condition Tolerance Calculator
Geometric Dimensioning & Tolerancing Training Available!
Tolerance Analysis Classes!
For the equations behind this calculator, see:
"Geometric Boundaries"
Interpretation and Application of
Geometric Dimensioning and Tolerancing
This calculator will determine the unknown variable of a floating fastener design condition using ASME Y14.5 - 2009 and ISO 1101 and derivative GD&T standards.
Negative Tolerance Numbers Indicate an Interference Condition
This calculator will calculate the unknown for the given conditions.
Two
(2) inputs are required,&  See the application illustration at bottom of page.
Open Floating Fastener Condition Tolerance Calculator
Fastener (Shaft) Diameter - This is the maximum size (MMC) of the bolt, shaft or other feature of size.
Hole Diameter - This is the smallest hole (MMC) for the given feature of size.
TOL = Hole Tolerance, This is the hole positional tolerance applied to all related hole features.
Applies to both plates #1 and #2.
Related Resources:
