Engineers Edge
Dry Room, Chamber Review
Environmental Chamber Menu
Dry Rooms or Chambers are also referred to as low humidity dry rooms; are specifically design for storage within a very low humidity environment. The chambers or rooms are typically equipped with dehumidifiers to remove water vapor. Units may employ sealed and locked doors, sensor and alarm systems to monitor and notify responsible individuals on the rooms humidity levels.
Typical applications include: storage of art, antiquities, processing pharmaceuticals, and semiconductor manufacturing.
Courtesy:
Scientific Climate Systems, Inc.
www.engineersedge.com
Advertising | Contact
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
