Electrical Equations ( Alternating Current ) AC - Engineers Edge
Instrumentation, Electrical, Control and Sensing Devices
Electrical circuits and alternating current AC equations anf formulae.
AC  Equations
DESIRED
DATA
ALTERNATING CURRENT
DIRECT
CURRENT
Single-Phase
Two-Phase*
Four-Wire
Three-Phase
Amperes when
kva is shown
kva x 1000
E
kva x 1000
2 x E
kva x 1000
1.73 x E
kva x 1000
E
Amperes when
kilowatts are shown
kw x 1000
E x pf
kw x 1000
2 x E x pf
  kw x 1000
1.73 x E x pf
kw x 1000
E
Amperes when
horsepower is shown
  hp x 746
E x %Eff x pf
    hp x 746
2 x E x %Eff x pf
     hp x 746
1.73 x E x %Eff x pf
hp x 746
E x %Eff
Kilovolt-Amperes
I x E
1000
I x E x 2
1000
I x E x 1.73
1000
I x E
1000
Kilowatts
I x E x pf
1000
I x E x 2 pf
1000
I x E x 1.73 x pf
1000
I x E
1000
Horsepower
I x E x %Eff x pf
746
I x E x 2 x %Eff x pf
746
I x E x 1.73 x %Eff x pf
746
I x E x %Eff
746
OHMS LAW
 Volts (E) = Amps (I) x Ohms (R)
Amps (I) = Volts (E) / Ohms (R)
Ohms (R) = Volts (E) / Amps (I) R=Ohms, E=Volts, I=Amperes
POWER - AC CIRCUITS
Efficiency = 746 x Output HP / Input Watts
3 KW = Volts x Amps x PF x 1.732 / 1000
3 Amps = 746 x HP / 1.732 x Eff. x PF
3 Eff. = 746 x HP / 1.732 x Volts x Amps x PF
3 PF = Input Watts / Volts x Amps x 1.732
1 KW = Volts x Amps x PF / 1000
1 Amps = 746 x HP / Volts x Eff. x PF
1 Eff. = 746 x HP / Volts x Amps x PF
1 PF = Input Watts / Volts x Amps
HP (3) = Volts x Amps x 1.732 x Eff. x PF / 746
HP (1) = Volts x Amps x Eff. x PF / 746
1 KW = 1000 Watts
Eff. = Efficiency, PF = Power Factor
KW = Kilowatts
HP = Horsepower
