Soil Cohesion Table
Soil Cohesion is the component of shear strength of a rock or soil that is independent of interparticle friction. In soils , true cohesion is caused by following: Electrostatic forces in stiff overconsolidated clays (which may be lost through weathering)
Typical soil cohesion values for different soils
The soil cohesion depends strongly on the consistence, packing, and saturation condition. The values given below correspond to normally consolidated condition unless otherwise stated. These values should be used only as guidline for geotechnical problems; however, specific conition of each engineering problem often needs to be considered for an appropriate choice of geotechnical parameters.
Description
Cohesion [kPa]
min
max
Nominal
Well graded gravel, sandy gravel, with little or no fines
0
Poorly graded gravel, sandy gravel, with little or no fines
0
Silty gravels, silty sandy gravels
0
Clayey gravels, clayey sandy gravels
20
Well graded sands, gravelly sands, with little or no fines
0
Poorly graded sands, gravelly sands, with little or no fines
0
Silty sands
22
Silty sands - Saturated compacted
50
Silty sands - Compacted
20
Clayey sands
5
Clayey sands - Compacted
74
Clayey sands -Saturated compacted
11
Loamy sand, sandy clay Loam - compacted
50
75
Loamy sand, sandy clay Loam - saturated
10
20
Sand silt clay with slightly plastic fines - compacted
50
Sand silt clay with slightly plastic fines - saturated compacted
14
Inorganic silts, silty or clayey fine sands, with slight plasticity
7
Inorganic silts and clayey silts - compacted
67
Inorganic silts and clayey silts - saturated compacted
9
Inorganic clays, silty clays, sandy clays of low plasticity
4
Inorganic clays, silty clays, sandy clays of low plasticity - compacted
86
Inorganic clays, silty clays, sandy clays of low plasticity - saturated compacted
13
Mixture if inorganic silt and clay - compacted
65
Mixture if inorganic silt and clay - saturated compacted
22
Organic silts and organic silty clays of low plasticity
5
Inorganic silts of high plasticity - compactd
10
Inorganic silts of high plasticity - saturated compacted
72
20
Inorganic clays of high plasticity
25
Inorganic clays of high plasticity - compacted
103
Inorganic clays of high plasticity - satrated compacted
11
Organic clays of high plasticity
10
Loam - Compacted
60
90
Loam - Saturated
10
20
Silt Loam - Compacted
60
90
Silt Loam - Saturated
10
20
Clay Loam, Silty Clay Loam - Compaced
60
105
Clay Loam, Silty Clay Loam - Saturated
10
20
Silty clay, clay - compacted
90
105
Silty clay, clay - saturated
10
20
Peat and other highly organic soils
References
  • Swiss Standard SN 670 010b, Characteristic Coefficients of soils, Association of Swiss Road and Traffic Engineers
  • Minnesota Department of Transportation, Pavement Design, 2007
  • NAVFAC Design Manual 7.2 - Foundations and Earth Structures,SN 0525-LP-300-7071, REVALIDATED BY CHANGE 1 SEPTEMBER 1986
