Structural Lumber Engineering Properties 5" to 5" Thick and Wider
Civil Engineering Design Knowledge
Structural lumber engineering properties for sizes 5' x 5'. Data includes lumber grade, fiber stress, tension in parallel compression ratings, and modulus of elasticity.
Structural Lumber Engineering Properties 5" x 5" thick and wider
Size Grade Extreme Fiber Stress in Bending
"Fb"1
Single Member Uses
Tension
Parllel
to Grain
"Ft"
Horizontal
Shear
"Fv"
Compression
Perpendicular
to Grain
Compression
Parallel
to Grain
"Fc"
Modulus
of
Elasticity
"E"
5" x 5"
and larger
Dense Select Structural
Select Structural
No. 1 Dense
No. 1
No. 2 Dense
No. 2
1750
1500
1550
1350
975
850
1200
1000
1050
900
650
550
110
110
110
110
100
100
440
375
440
375
440
375
1100
950
975
825
625
525
1,600,000
1,500,000
1,600,000
1,500,000
1,300,000
1,200,000
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
