Thread Yield and Tensile Strength Equation and Calculator
Fastener and Screw / Bolt Design, Formula and Calculations
The following Equation and Calculator will determine the working loads base on the ultimate yield strength threaded connections.
Tensile Stress-Strain Diagram
Ultimate Strength of a thread
ymin = syield x a
Ultimate Tensile Strength of a thread
stensile = tmin x a
Shear Strength of a thread
Ssy = pr x syield
ymin = Minimum Yield of bolt threads engaged (lbs)
syield = Minimum yield strength of the bolt grade, ASTM, SAE, etc. (psi)
stensile = Ultimate Yield Strength (lbs)
tmin = Minimum tensile strength of the bolt grade, ASTM, SAE, etc. (psi)
Ssy = Working axial load of fastener bolt (lbs)
a = Stress area of thread (in2)
pr = Percent expressed as decimal, e.g. 60% = 0.6 - This is the factor of safety (FOS) for the design application
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
