Angular / Radial Contact Ball Bearings Static Load Rating Calculator
Bearings Application Knowledge Menu
Bearings and Bushings Products & Supply
To calculate the static load rating for Angular / Radial Contact Ball Bearings, use the following the equation:
Open Angular Radial Contact Ball Bearings Static Load Rating Equations Description
Variables
Constant static load rating ball bearings (Fo) =
Rows of bearing balls (i) =
Number of bearing balls each row (Z) =
Bearing ball diameter (D) inches =
Bearing ball contact angle degrees () =
Results
Load Rating Co =
Automatic recalculation
