GD&T Spherical True Position Tolerance Calculator and Equation
Spherical Diameter True Position Explanation
This calculator calculates  position tolerances utilizing principles and concepts within ASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
Variables Used in Spherical True Position GD&T Calculator
This Spherical True Position calculator will convert coordinate measurements to position tolerances.  >Two (3) inputs are required.
Geometric Dimensioning Tolerancing Design Variables
Units
mm
inches
X Offset
Y Offset
Z Offset
Results
Spherical Radius (R) Offset
Spherical Diameter (S) True Position
Automatic recalculation
Related Resources:
