Pressure Vessel Wall Thickness of Longitudinal Shells With Internal Pressure Applied Calculator
Pressure Vessel Design and Calculators
This calculator determines the thickness of a circumferential shell with an internal pressure applied: Typical applications are propane tanks, compressed air storage tanks etc.
The "Joint Efficiency" reflects your confidence in the welded seam areas of the as-manufactured pressure vessel.
Note: When Thickness does not exceed one-half of the inside radius, or P does not exceed 1.25SE, use the following calculator.
Thickness of Longitudinal Shells Under Internal Pressure:
Design Variables:
(P) = Design Pressure (internal) (psi) =
(R) = Inside radius of shell under consideration (in.) =
(S) = Maximum Allowable Stress value (psi) =
(E) Weld Joint Efficiency (80% = .80) =
Result:
Minimum required wall  thickness of shell (inches) =
