Area Moment of Inertia Section Properties: Rectangle at Specified Angle
Strength of Materials
Area Moment of Inertia Section Properties: Rectangle at Specified Angles
Area Moment of Inertia Section Properties of Rectangle at Specified Angles Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description
Equation
Area Moment of Inertia Section Properties = I
Moment of Inertia
Section Modulus = Z = I/y
Section Modulus
Radius of Gyration
Radius of Gyration
A = area
A = db
y = Distance to neutral axis
Dsitance
Variables
Inputs Inches mm
"b" Width =
"d" Height =
"deg" Angle =
Calculated Properties Inches mm
Area Moment of Inertia Section Properties (Unit4) =
Section Modulus (Unit3) =
Radius of Gyration (Unit) =
Area (Unit2) =
y = (unit) =
