Area Moment of Inertia Section Properties Square Tube Rotated 45 Deg at Center Calculator
Strength of Materials
Area Moment of Inertia Section Properties Square Tube Rotated 45 Deg at Center Calculator and Equations
This engineering calculator will determine the Area Moment of Inertia Section Properties for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members. There are two types of section moduli, the elastic section modulus (S) and the plastic section modulus (Z).
Description
Equation
Area Moment of Inertia Section Properties = I
Section Modulus = Z = I/y
Section Modulus
Radius of Gyration
A = area
y = distance from axis to extreme fiber
Distance to center fiber
Section Properties Rotated Square Tube
Variables
Inputs Inch mm
Length a (in, mm) =
Length b (in, mm) =
Calculated Properties
Area Moment of Inertia Section I (in4, mm4) =
Section Modulus  (in3, mm3) =
Radius of Gyration (in3, mm3) =
Distance y (in, mm) =
Area (Unit2) =
