Engineers Edge
Area Moment of Inertia Section Properties Square
Rotated 90 Deg @ Center Calculator
Strength of Materials
Area Moment of Inertia Section Properties Square Rotated 90 Deg at Center Calculator and Equations
This engineering calculator will determine the Area Moment of Inertia Section Properties and section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members. There are two types of section moduli, the elastic section modulus (S) and the plastic section modulus (Z).
Description
Equation
Area Moment of Inertia Section Properties = I
Moment of Inertia
Section Modulus = Z=I/y
Section Modulus
Radius of Gyration
Radius of Gyration
A = area
Area
y = distance from axis to extreme fiber
Dist. to extreme fiber
Square Rotated 90 Deg @ Center Calculator
Variables
Inputs:
"a"  (Side of Square)
Calculations:
Area Moment of Inertia Section Properties (Units4)
Section Modulus (Units3)
Radius of Gyration (Units)
Extreme Point (Units)
Area (Units2)
