Engineers Edge
Area Moment of Inertia Section Properties Half Tube Calculator
Strength of Materials
Area Moment of Inertia Section Properties: Half Tube Calculator
Area Moment of Inertia Section Properties of Half Tube Feature Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description
Equation
Area Moment of Inertia Section Properties = I
Moment of Inertia
Section Modulus = Z = I/y
I/y
Radius of Gyration = G
Radius of Gyration
area =A
Area
Distance to neutral axis = y
Distance
Variables
Inputs Inches mm
"R" (Outside Radius) =
"r" (Inside Radius) =
Calculated Properties Inches mm
Area Moment of Inertia I (Units4) =
Section Modulus Z (Units3) =
Radius of Gyration G (Unit) =
Area A (Unit2) =
Distance to Neutral Axis y = (unit)
