Area Moment of Inertia Section Properties: Parabolic Spandrel Calculator
Section Properties Equations and Calculators
Area Moment of Inertia Section Properties: Parabolic Spandrel Section Properties Calculator
Area Moment of Inertia Section Properties of Parabolic Spandrel Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Variables
Inputs Inch mm
Length h (in, mm) =
Length b (in, mm) =
Length x' (in, mm) =
Calculated Properties
Distance y' (in, mm) =
Distance y (in, mm) =
Distance x (in, mm) =
Area (in2, mm2) =
Parabolic Spandrel Section Equation Used
Description
Equation
Distance to neutral axis y' (in, mm) =
x' h / b2
Distance to neutral axis y (in, mm) =
3h / 5
Distance to neutral axis x (in, mm) =
3b / 8
Area A (in2, mm2) =
2bh / 3
