Engineers Edge
Design Assembly Mass Estimation Work Sheet
Engineering Calculators | Engineering Analysis
Mass of an Assembly Estimation
Assembly Mass Estimate Work Sheet
Component Unit Weight (g) Qty/Assembly Total Weight (g) High (g) Low (g) Contingency *
Totals:
*Recommendations:
Estimated (20%)
Calculated (10%)
Solid CAD model (5%)
Measured (2%)
Automatic recalculation
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
Copyright 2000 - 2005, by Engineers Edge, All rights reserved.  Disclaimer
