Hollow Shaft Cylinder Mass Moment of Inertia
Section Properties Menu
Strength of Materials
Shaft Cylinder Mass Moment of Inertia Equations and Calculators
This engineering calculator will determine the mass moment of inertia from the data inpouts as provided. Keep the unit consistant for correct answers.
Hollow Cylinder Mass Moment of Inertia
I = 1/2 m ( Ri2 + Ro2 )
m = Mass of Hollow Shaft Cylinder(lb m , kg)
R i = Distance Between Bxis and Inside Hollow Shaft Cylinder (ft, m)
R o = Distance Between Bxis and Butside Hollow Shaft Cylinder(ft, m)
Design Variables
Ri (in, mm) =
Ro (in, mm) =
m (lbs, g) =
Results
I (lbm-in2, g-mm2)
