Section Modulus I-BeamNeutral Axis at Bottom Edge Equation and Calculator
Section Modulus Equations Calculators Common Shapes
Section Modulus Calculator and equation for I beam with center neutral axis. Other geometric properties used in design include area for tension, radius of gyration for compression, and moment of inertia for stiffness. Any relationship between these properties is highly dependent on the shape in question.
Notes:
Keep units consistant for the input design variables inches or mm.
I Beam Section Modulus Section Modulus I Beam
This calculator Requires a Premium Membership
www.engineersedge.com
Advertising | Contact
