Engineers Edge
Energy To Work Equivalents Calculator
To use this energy to Work conversion calculator enter from number in top box and then press "Click for Conversion" button.
First, type the number you wish converted here:
Then, click radio buttons for desired conversion:
Kg-meters
Ft-lbs
Kw-hrs
Metric Hp-hrs
US Hp-hrs
Liter-atm
K-cal
Btu
To: Joules
Kg-meters
Ft-lbs
Kw-hrs
Metric Hp-hrs
US Hp-hrs
Liter-atm
K-cal
Btu
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
