Compression Spring "k" Constant Calculator
Spring Design Menu
Compression Spring
This calculator will deterine the Compression Spring Constant (k). Compression spring – is designed to operate with a compression load, so the spring gets shorter as the load is applied to it.
To see the equations behind this calculator ->
Compression Spring Rate Constant (k) Equation .
Compression Spring Constant (k) Calculator
Design Variables
Modulus of Rigidity, psi (G) =
Wire Diameter (d) =
Number of Active coils (n) =
Mean Diameter of Spring Coil (D) =
Results
Spring Constant (k) =
Automatic recalculation
