Bolt Single and Double Shear and Tension Stress Analysis Calculator per AISC
Strength of Materials
This calculator will determine bolt stress in tension and shear per AISC 9th Edition Manual (ASD)
This "Bolt Stress" analysis calculator checks allowable bolt tension and bolt shear against the applied values. High strength bolts from 3/4" up through 1-1/2" diameter are assumed. Effects of fatigue are considered if required. Bolts can be in either single or double shear. AISC 9th Edition Manual (ASD) is used.
