Ball Bearings Fatigue Life and Load Ratings Calculator
Bearings Application Knowledge Menu | Ball Bearings Suppliers
Bearings and Bushings Products and Supply
Fatigue life calculations assume the dispersion in life of identical ball bearings operating under identical conditions, a statistical result is obtained for bearing fatigue life.
Open Ball Bearings Fatigue Life Calculations and Load Ratings Equations
Variables
Life adjustment Factor for reliability see vendor (a1) =
Life adjustment Factor for Ball Bearing Material (a2) =
Life adjustment Factor for Application Conditions (a2) =
Operating Speed RPM (N) =
Extended Basic Dynamic Load Rating Radial Ball Bearings lbs or N (CE) =
Equivalent Radial Load on Bearing lbs or N (P) =
Dynamic Load rating Adjustment factor for Number of Adjacently Mounted Bearings (fB) =
Results
Life in hours (Ln) =
Automatic recalculation
