W-Flange Overhead Monorail Beam Analysis Calculator
Description and References for This Calculator
MONORAIL BEAM ANALYSIS
For W-shaped Underhung Monorails Analyzed as Simple-Spans with / without Overhang
Per AISC 9th Edition ASD Manual and CMAA Specification No. 74 (2004)
Input:
Monorail Size:
Select:
Design Parameters:
Beam Fy =
ksi
Beam Simple-Span, L = ft.
Unbraced Length, Lb = ft.
Bending Coef., Cb =
From AISC 9th Edition ASD Manual, page 5-47:
Cb = 1.75+1.05*(M1/M2)+0.3*(M1/M2) <= 2.3
where: M1/M2 = ratio of smaller to larger bending moment at ends
of the unbraced length, 'Lb'.
Overhang Length, Lo = ft.
Unbraced Length, Lbo =
The unbraced length for the overhang (cantilever) portion, 'Lbo', is often debated.
Here are some recommendations from different sources:
1. Per Fluor Enterprises Guideline 000.215.1257 - "Hoisting Facilities"
Lbo = Lo+L/2
2. Per Dupont Standard DB1X - "Design and Installation of Monorail Beams"
Lbo = 3*Lo
3. Per ANSI MH27.1 - "Underhung Cranes and Monorail Systems"
Lbo = 2*Lo
4. Per British Steel Code B.S. 449, pages 42-44 (1959)
Lbo = 2*Lo (for top flange of monorail beam restrained at support)
Lbo = 3*Lo (for top flange of monorail beam unrestrained at support)
5. Per AISC Journal article by N. Stephen Tanner - "Allowable Bending Stresses
for Overhanging Monorails" (3rd Quarter, 1985)
Lbo = Lo+L (used with a computed value of 'Cbo' from article)
ft.
Bending Coef., Cbo =
Lifted Load, P = kips A = in.^2 d/Af =
Trolley Weight, Wt = kips d = in. Ix = in.^4
Hoist Weight, Wh = kips tw = in. Sx = in.^3
Vert. Impact Factor, Vi = % bf = in. Iy = in.^4
Horz. Load Factor, HLF = % tf = in. Sy = in.^3
Total No. Wheels, Nw =
k= in. J = in.^4
Wheel Spacing, S = ft. rt = in. Cw = in.^6
Distance on Flange, a = in.
Support Reactions:
Results:
RR(max) =
For a monorail consisting of a simple-span with no overhang, 'RR(max)' and 'RL(min)' are determined by positioning the trolley at the right support.
For a monorail consisting of a simple-span with an overhang, 'RR(max)' and 'RL(min)' are determined by positioning the trolley at the end of the overhang.
The self-weight of the monorail beam is also included.
RL(min) =
Parameters and Coefficients:
Pv = kips
Pw = kips/wheel
Ph = kips
ta = in.
l =
l = 2*a/(bf-tw)
Cxo =
Cxo = -2.110+1.977*l+0.0076*e^(6.53*l)
Cx1 =
Cx1 = 10.108-7.408*l-10.108*e^(-1.364*l)
Czo =
Czo = 0.050-0.580*l+0.148*e^(3.015*l)
Cz1 =
Cz1 = 2.230-1.490*l+1.390*e^(-18.33*l)
Bending Moments for Simple-Span:
x = ft.
Mx = ft-kips
My = ft-kips
Lateral Flange Bending Moment from Torsion for Simple-Span:
(per USS Steel Design Manual, 1981)
e = in.
at =
Mt = ft-kips
X-axis Stresses for Simple-Span:
fbx = ksi
SR =
Lb/rt =
Fbx = ksi
(continued)
Y-axis Stresses for Simple-Span:
fby = ksi
fwns = ksi
fby(total) = ksi
Fby = ksi
SR =
Combined Stress Ratio for Simple-Span:
S.R. =
SR =
Vertical Deflection for Simple-Span:
Pv = kips
D(max) = in. D(max) =
D(ratio) =
D(ratio) = L*12/D(max)
D(allow) = in. D(allow) = L*12/450
SR =
Bending Moments for Overhang:
Mx = ft-kips
My = ft-kips
Lateral Flange Bending Moment from Torsion for Overhang:
e = in.
at =
Mt = ft-kips
X-axis Stresses for Overhang:
fbx = ksi
Lbo/rt =
Fbx = ksi
SR =
Y-axis Stresses for Overhang:
fby = ksi
fwns = ksi
fby(total) = ksi
Fby = ksi
SR =
Combined Stress Ratio for Overhang:
S.R. =
SR =
Vertical Deflection for Overhang:
Pv = kips
D(ratio) =
D(ratio) = Lo*12/D(max)
D(allow) = in. D(allow) = Lo*12/450
SR =
Bottom Flange Bending (simplified):
be = in.
am = in.
Mf = in.-kips
Sf = in.^3
fb = ksi
Fb = ksi
SR =
Bottom Flange Bending per CMAA Specification No. 74 (2004):
(Note: torsion is neglected)
Local Flange Bending Stress @ Point 0:
(Sign convention: + = tension, - = compression)
sxo = ksi sxo = Cxo*Pw/ta^2
szo = ksi szo = Czo*Pw/ta^2
Local Flange Bending Stress @ Point 1:
sx1 = ksi sx1 = Cx1*Pw/ta^2
sz1 = ksi sz1 = Cz1*Pw/ta^2
Local Flange Bending Stress @ Point 2:
sx2 = ksi sx2 = -sxo
sz2 = ksi sz2 = -szo
Resultant Biaxial Stress @ Point 0:
sz = ksi sz = fbx+fby+0.75*szo
sx = ksi sx = 0.75*sxo
txz = ksi txz = 0 (assumed negligible)
sto = ksi sto = SQRT(sx^2+sz^2-sx*sz+3*txz^2)
SR =
Resultant Biaxial Stress @ Point 1:
sz = ksi sz = fbx+fby+0.75*sz1
sx = ksi sx = 0.75*sx1
st1 = ksi st1 = SQRT(sx^2+sz^2-sx*sz+3*txz^2)
SR =
Resultant Biaxial Stress @ Point 2:
sz = ksi sz = fbx+fby+0.75*sz2
sx = ksi sx = 0.75*sx2
st2 = ksi st2 = SQRT(sx^2+sz^2-sx*sz+3*txz^2)
SR =
Contributed by:
Harsh Murugesen
Pune, Maharasha India
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
