Beam Deflection Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at Defined Center Location
Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at Defined Center Location
Beam Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
Vmax = Shear Load lbf (N)
Mmax = Beam Moment lbs-in (N-mm)
σmax = Beam Stress max. psi (N/mm2)
