Bending, Deflection and Stress Equations Calculator for
Beam Supported on Both Ends Loaded at any Location
Structural Beam Deflection, Stress, Bending Equations and calculator for Beam Supported on Both Ends Loaded at any Location.
Open
Beam Deflection, Stress Beam Supported on Both Ends Calculator
Stress between load and "a" load point
Stress between load and "b" load point
Stress at load application
If the cross section is constant this is the maximum stress.
Deflection for location between load and "a" point
Deflection between load and "a" point
Deflection for location between load and "b" point
Deflection between load and "b" point
Maximum deflection at load
Let be the length of the shorter segment and b of the longer one.
The maximum deflection
Beam  Deflection is in the longer segment, at
Beam Deflection
E = Modulus of Elasticity lbs/in2
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated lbs/in2 (N/mm2)
y = Deflection inches (mm)
a = Some distance as indicated inches (mm)
b = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 404 or,
  • Machinery's Handbook, 23st Edition, Page 260 or,
  • Machinery's Handbook, 27st Edition, Page 261
