Beam Deflection Calculator, Shear and Stress Equations for a Beam supported One End Cantilevered with Reversed Tapered Load
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limted Tapered Load
Beam Moment Load Equation
Bending Moments Equation
Stress Maximum
E = Modulus of Elasticity psi
(N/mm2)
W = Beam Load, Total lbf (N)
w = Beam Unit Load lbs/in (N/mm)
Vmax = Beam Shear Load lbf (N)
Mmax = Beam Moment lbs-in (N-mm)
θmax = Beam Slope Angle degree (radian)
σmax = Beam Stress max. psi (N/mm2)
