Beam Deflection and Beam Stress Equations Calculator for Fixed at One End, Supported at the Other, Load at Center
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at One End, Supported at the Other, Load at Center.
Beam Deflection and Stress Fixed at One End, Supported at the Other, Load at Center
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
Beam Loads and Moment at Reaction points as Defined
Open: Loads at Reaction points as Defined Beam Calculator
General Beam Stress at any Given Point
Beam Stress between point of fixture and load
Open: Stress Between Point of Fixture and Load Beam Calculator
Beam Stress Between support and load
Open: Stress Between Support and Load Beam Calculator
Beam Stress at Critical Locations/Points
Maximum Beam stress at point of fixture
Open: Stress Maximum at Point of Fixture Load Beam Calculator
Beam Stress is zero at x = (3⁄/1l)l
Greatest negative Beam stress at center
Open: Greatest negative stress at center Beam Calculator
Beam Deflection at any Point
Between point of fixture and load
Beam Deflection Between point of fixture and load
Open: Deflection between point of fixture and load Calculator
Beam Deflection Between support and load
Open: Deflection between support and load Calculator
Critical Beam Deflections
Maximum Beam deflection
v = 0.4474l
or
Open: Maximum Deflection Calculator
Beam Deflection at load
Open: Deflection at load Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
