Beam Stress and Beam Deflection Formula and Calculator Beam Both Ends Overhanging Supports Symmetrically, Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam supported Both Ends Overhanging Supports Symmetrically, Uniform Load
Beam Stress and Deflection Supported Beam
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Adjacent end stress:
Open: Adjacent End Stress Beam Calculator
Beam Stress Between indicated supports
Open: Between Indicated Supports Beam Calculator
Beam Stress at Critical Locations/Points
Stress at each support:
Open: Stress at Each Support Beam Calculator
Beam Stress at Center of Beam.
Open: Stress at Center of Beam Calculator
Beam Stress at support next to end of length d:
If l is greater than 2c, the stress is zero at points
Beam Stress On both sides of the center
If cross-section is constant and if l = 2.828c, the stresses at supports and center are equal and opposite, and are:
Beam Deflection at any Point
Between supports
Open: Deflection Between Supports Calculator
Beam Deflection Between each support and adjacent end,
Open: Deflection Between each Support and Adjacent End Calculator
Beam Deflection at Ends
Open: Deflection at Ends Calculator
E = Modulus of Elasticity psi
(N/mm2)
Z = Section modulus of the cross-section of the beam I/z in3 (mm3)
z = distance from neutral axis to extreme fiber (edge) inches (mm)
W =   Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
c = Distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
