Beam Free and Guided on One End, Rigid one End With Single Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Free and Guided on One End, Rigid one End With Uniform Load.
Beam Stress Deflection Free One End, Rigid one End Single Load Calculator
Open
Stress at Any Point
Stress at the fixed support
Deflection at specified point
Deflection at the free end
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 410 or,
  • Machinery's Handbook, 23st Edition, Page 265 or,
  • Machinery's Handbook, 27st Edition, Page 267
